Tesla style head unit installs - does anyone regret it?
  • Hello all. While I don't mind the stock set up in my 2018 Cascada, I do like to have a larger screen to view maps, etc on. With that said, I am seriously debating buying a Tesla style head unit from AliExpress that I'll install myself.
    My question is, for those here who have done that, do you have any regrets?
    I did try one of these style head units in my 2011 Cadillac CTS several years ago. While it was nice enough, it was one of the really early versions that ran KitKat 4.4 and could not be upgraded. It was painfully slow, but with the help of a member of the XDA Forum (and a reasonable price), I had a custom ROM built that I flashed and made things better. I know these newer units should be faster, so my only real concern today is CAN bus compatibility, and will it properly interface with my Buick (can I set AC controls to Fahrenheit, will the time display without leading zero's, stuff like that).
    BTW, this is the one I'm looking at: https://www.aliexpress.us/item…ayAdapt=glo2usa4itemAdapt
  • Hello and welcome. Perhaps as a suggestion, since the forum is in German, it would be helpful for everyone's convenience to use a translator like I do. I write in Spanish from Spain and respect the original language, although it makes me uncomfortable not being able to express myself as I'm used to. That said, in my case, I don't regret it at all. You'll just have to make sure there's no phantom power consumption from the unit. I don't know why, but many Chinese radios, regardless of the model, have phantom power consumption. You can choose Celsius or Fahrenheit, and all the information you want, be it hours or temperatures. They are usually very complete and quick to use. I wish you luck! ;)
    Cascada 1.6 turbo Manuelle, mineralweiße, schwarze Ledersitze AGR, Felgen 19, Heiß auf Genuss!! 8o
  • Hallo Paul,
    ich bereuhe die Umrüstung nicht. Immer ein aktuelles Navi, der große Bildschirm. Top. Ich würde es jederzeit wieder tun. Habe das "größte" Radio von Ebilean eingebaut.
    Marco
    Hello Paul, I don't regret the upgrade. Always an up-to-date navigation system, the large screen. Great. I would do it again anytime. I installed the "biggest" radio from Ebilean.
    Regards, Marco
  • Here goes my attempt at using a translator, I hope this is understandable!
    Vielen Dank an euch beide für die Antwort. Vorerst habe ich mich entschieden, beim Werksradio zu bleiben. Mein größtes Problem mit dem Werksradio ist das fleckige Bluetooth, aber ich habe das gelöst, indem ich einen Bluetooth-Adapter installiert habe, der an den AUX-Anschluss angeschlossen wird. Ich habe den AUX-Anschluss unter die Konsole verschoben und an seiner Stelle einen weiteren USB-Anschluss installiert. Der Adapter verbindet sich sofort mit meinem Telefon und startet meinen Musikstream sofort, ganz ohne Aussetzer. Ich bin jetzt sehr zufrieden mit meinem Setup! Und ja, beide USB-Anschlüsse sind funktionsfähig, da ich einen Y-Splitter mit Teilen von Amazon herstellen konnte. Nicht verwandt, aber ich habe auch den Stromanschluss entfernt und einen Kofferraumentriegelungsknopf von einem 2005er Pontiac G6 (für die rote Hintergrundbeleuchtung) eingebaut. Ich habe einen Gurt gemacht, hatte aber keine Zeit, ihn nach hinten und in den Kofferraum zu führen.
  • Schöner Knopf, sieht aus, als wäre er werkseitig eingebaut... Da ich sehe, dass Sie ein begeisterter Heimwerker sind, empfehle ich Ihnen, mit dem Tesla-Display fortzufahren. Hier sind alle Informationen. Ich habe bei Null angefangen und es hat lange gedauert, aber Sie könnten alles in nur wenigen Stunden haben. 8o
  • Vielen Dank für das Kompliment auf dem Kofferraumknopf. Ich werde es mir vielleicht noch einmal überlegen, das Tesla-Radio zu installieren, aber nicht in diesem Jahr. Ich werde abwarten, bis sich diese dummen Zollkriege gelegt haben, und sehen, ob Aliexpress nächstes Jahr wieder einen besseren Preis hat.
